Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
iPhone 5S water damaged
I put my iPhone 5S in the washing machine and dried it in the rice box for 3 days. After 3 days, when the phone is plugged in, the screen turn on and show the Apple's logo for 0.5-1 sec and turn black. The screen just show a black image but not totally turn off. iTunes can't recognize my phone.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Unfortunately, the worst thing you could possibly do was to let water fester and corrode your phone for a few days while it was sitting in rice. The water is in the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is...it cannot help your phone.
When the water is allowed to evaporate, it leaves deposits of minerals that can cause short circuits or corrosion. Heating or powering the phone accelerates the process. The water needs to be displaced, not heated and evaporated.
Sorry about that, now on to helping you.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
  • Use a tool like 3uTools to flash the firmware as it may be corrupted.
  • You should also consider getting a new battery
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
War diese Antwort hilfreich?
Bewertung 4
take a look here
Electronics Water Damage
Bewertung 1
Antwort hinzufügen
toanvu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 4,548
