Stoped working at all
My dolce Gusto stoped working when connected to electricity. Light does not even appear
Ist dies eine gute Frage?
I think you should check your Dolce Gusto Genio’s mainboard(motherboard) or power port.
Then I think you could fix it.
Have a good day^^
War diese Antwort hilfreich?
looks like that signal form switch (hot water lever) goes to main board, but then what?
Maybe you know where should I start?
I'm sorry, I misinformed you earlier.
Let me correct what I said earlier.
I think your Dolce Gusto fuse is broken so it doesn't working.
Here's a link to a YouTube video that tells you how to fix it.
Link : https://www.youtube.com/watch?v=aja0DsBO...
Link for your Dolce Gusto's fuse (SF129E) : https://www.amazon.com/SF129E-SEFUSE-Cut...
I hope you'll be able to repair it.
Have a nice day.
ahh thank you for a suggestion, checked my fuses.
But all of them looks normal.
So still looking for my problem
it happened to me months ago and finally fixed it today. The on/off switch consists of a piece of conductive rubber that makes contact with the circuit underneath. In my case the circuit or rubber became misaligned or dirty.
Either way what fixed it was to disassamble the switch side carefully, remove the switch rubber, clean it and the circuit with some q-tips dabbed with alcohol and reassamble all.
Deassembly was the biggest pain.
There are two thermal fuses in the back, above the boiler. Replace them both.
You’ll have to take it apart.
Letzte 24 Stunden: 1
Letzte 7 Tage: 53
Letzte 30 Tage: 206
Insgesamt: 37,177
6 Kommentare
Does it work when its not connected? When did this occur? How long have you had it?
von Cameron
My machine is only 5 months old. In 2 years I had 3 machines
von Danie Swanepoel
Hi got a Nescafé Dolce gusto machine and input a discaler through it yesterday as not running quite so smoothly . Did it and rinsed it through all ok. I went to use it and nothing the red light come on then the green been when it's a constant green unmove the swit h over to hot and nothing happens ? Any ideas
Thanks
von andywheatley1
Have the same problem, how do you resolve it?
von Gal Val
ive had my Krups Piccolo Xs Manual Coffee Machine for 2 days i used it once now not working, no lights on, cant even take pods out it seems jammed? ive tried different sockets, assuming its not the fuse as its only couple days old, any ideas? please i need a coffee hahha
von briana
1 weiteren Kommentar anzeigen
