Zum Hauptinhalt wechseln
Repair information for the Stealth 500P by Turtle Beach. The Stealth 500P is an wireless gaming headset optimized for PS3 and PS4 consoles.
17 Fragen Alle anzeigen
Volume knob stuck at highest setting
My stepdad bought me the Turtle Beach Ear Force Stealth 500P headset two years ago and recently the volume control stopped working. Currently it's stuck at the highest setting. So, when I play some games that does not have their own volume control it's super loud to the point where I can't play it with my headset without causing my ears to explode. Anyone else have this issue and possibly a fix? Thank you!
Ist dies eine gute Frage?
Bewertung 5
7 Kommentare
I'm having the same problem. They were working fine and then suddenly the volume just turned up really loud and won't go down
von
Yeah, I have the same issue as well. I don't think anyone has the solution to this problem.
von
im having the sam issue with the stealth 400's im thinking either the scroll peices for the headphones are internally stripped or a solder broke.. =/ wont know for sure until I take them apart lol
von
Same issue here. I think i have had success putting side pressure on the roller when i adjust it but is is inconsistent. Any luck figuring out the cause? before i take mine apart also.
von
I have the same issue, about to ditch turtle beach since it’s a known issue and they won’t do anything about it.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
You're definitely not alone.
As mentioned in a comment in the link above, try power cycling them.
War diese Antwort hilfreich?
Bewertung 2
Here is the part I was able to get out. Where can I find the replacement
Bewertung 1
7 Kommentare:
ok, I have ended up removing the POT.
I am using the 400xp stealth in a PC application and before I had a full volume only. very hard to control with the pc volume control
with the pot removed, I can control the headsetbetter with the pc system volum controller
von
just figured out.
If I set the device up as Realtek digital audio device on PC and not select the Stealth, then my PC can control the sound without any issue. I which I tried that before I took off the pot.
von
Coxwain can you please explain what you did to fix the issue? Nothing happens when I switch to realtek and lower the volume. Still stuck on highest volume
von
I have this issue with my 420x and after some research the only fix i could find would be to replace the volume potentiometer but that requires taking the headset apart and soldering a new one in, no problem for me, but where does one find the super slim potentiometers used in these headsets?
Bewertung 0
9 Kommentare:
Take the potentiometer out, get the part number off from it, eBay the part number... Solved. Solder new one on when it arrives.
von
I have takent the part off the TB stealth 500p, here are the markings
CT1508
B104
now I have to try to find the potentionmeter to replace it
von
I think its a 16mm x2mm dial
von
I haven't had much luck. I finally got the 16x2 B104 which are 100k resistor potentionmeters and the sound is too faint.
not sure if there is another issue or not but I think I will abandon this project.
von
BTW I have extra potentiometers 16x2mm T104 if anyone wants a couple. I had to buy in bulk. Just pay a couple$ for shipping
von
4 weitere Kommentare anzeigen
Mine has the knob where you change chat volume stuck in the mic itself so I can't move it do you know how to fix that?
Bewertung 0
Antwort hinzufügen
Loyd Latture wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 40
Insgesamt: 16,683
