Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Home button loose after screen replacement
I had my iPhone 5s front panel assembly replaced because of glass damage and now the home button rocks in it's place. Seems like there may be a gasket or seal missing now. I have done a ton of googling and I can't seem to visually identify what might be missing from the home button assembly.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@efb115,Erik, Home button rocks. This could be because of bad/missing gasket or the button bracket not installed correctly. Below are links for replacement parts(bracket 1st link, gasket 2nd link) and also guides/vids to help open the device to check and make repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 5s/SE (1st Gen) Home Button Bracket
https://www.fixez.com/iphone-5s-home-but...
iPhone 5s Home Button ersetzen
https://www.youtube.com/watch?v=2NZgucac...
https://www.youtube.com/watch?v=SD_6oVXX...
iPhone 5s/SE (1st Gen) Home Button Bracket Bild
Produkt
$5.99
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
Yeah, the first thing I did was remove and reassemble the home button assembly and that didn't fix it. That black gasket is still there, but is there another adhesive pad or ring that goes between plastic button and the button sensor on the cable?
von
Erik Brandt, By the looks of the 1st and 2nd video link provided, the replacement gasket should have adhesive on both sides perhaps, the vids. show all parts used when install of home button.
von
The adhesive on the black home button rubber gasket has weakened / separated (probably on the old screen).
To fix this issue you will need to actually replace the current rubber home button gasket with a new one which will have adhesive on it.
I generally buy the iPhone 5s home button rubber gasket from eBay myself.
von
It is also possible that the aftermarket screen have a button hole that's is slightly larger than original screen.
Bewertung 1
Antwort hinzufügen
Erik Brandt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 22,996
