Zum Hauptinhalt wechseln
Demontage- und Reparaturanleitungen für Wecker.
101 Fragen Alle anzeigen
How can I diagnose a fault with the alarm clock control board?
The digital display will read the proper time for a short while then the read out will disappear If I can obtain a repair manual, that would go far toward diagnose the problem with my alarm clock.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @redbiship ,
Knowing the make and model of the clock would help in finding a repair manual.
Also is the problem only with the digital display? For instance assuming it is a clock /radio, if the radio is on does it also stop when the display disappears indicating more of a power problem then just a display problem.
More information from you as to the problem will give you better answers.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Most battery operated digital clocks are built to do that to save battery power. Pressing the button should bring it back to bright. I don't think anything is wrong with it.
Bewertung 1
Antwort hinzufügen
Sean Bigge wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 97
