Zum Hauptinhalt wechseln
Das Asus VivoBook X202E ist ein kleiner Laptop, der Ende 2012 veröffentlicht wurde. Er verfügt über einen 11,6-Zoll-Touchscreen und einen Intel-Prozessor der 3. Generation.
Problems with pointer/cursor and screen
I have a vivobook Q200E-BHI3T46 and some stranges behavior on the screen.
At the bottom half of the screen there is like a circle, transparent blinking. If a hyperlink hits that area it will be activated. Some times the cursor will be stacked there and cannot be moved or it split into two, one will be stacked there and the other can be moved around with certain difficulties , but it will do the job.
Could this be problems with the touchscreen and can the touchscreen be disable? or is it related to the graphic card ?
Pls help me out here because it is driving me nuts.
Tony
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
Hi,
Try starting the laptop in 'safe mode' and see if it happens.
Try disabling the touchpad (Fn +F9) and see what happens.
Connect a USB mouse, with the touchpad disabled and see if it works OK
What OS is installed?
von
its happened also in safe mode. Currently i am running windows 8.1 64 bit.
Downloaded drivers from asus.
von
Hi,
Did you install the latest Asus ATK package drivers "before" installing the latest Smart Gesture drivers?
The ATK package drivers are list underUtilities ATKACPI
https://www.asus.com/ae-en/support/Downl...
von
I am not really sure which one I installed first. The strange thing is the touchpad is working as normal and most of the time the pointer looks fine. I am using only half of the screen and a little to the right of the middle I can see something which look like its clicking on the screen.
I had the same problem when i was running windows 10. Asus told me then that my asus vivobook was not compatible with windows 10.
von
The problem seems to be solved. This is what I did. I followed the advice from jayjeff. De-installed both drivers and installed them back the way he told me. I also followed he advice and dissable the touch screen. After the last major monthly windows update everything startet to changes and the laptop started to behive. Many thank to all advice i got and special thanks to jayeff.
Tony
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi, Have you tried to disable the touchscreen in Device Manager > HID? Right click on touchscreen entry listing and select disable.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
tonyeikelmann wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 2,317
