Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
iPhone 5SE home button
Is it posible to repair the home button, when it font work when pressed on, there seems to be no signal when dressing it down and the normal feeling of click is not there.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Yes you can. iPhone 5s Home Button Einheit ersetzen
Although it's not so much repairing it but rather replacing it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
But, The Touch ID function will not work if you replace the home button.
von
absolutely.
you can buy a replacement part for it, and change it out. However, The touch ID will not function without pairing it to your motherboard. the software required for doing this is only obtainable for apple certification.
The button will work, but you wont be able to use your fingerprint.
you may be able to salvage the OEM part, by gluing a new nub onto the edge of the button, but i wont be able to guarentee that without actally having handled the button in a diagnosis.
Bewertung 0
It most likely needs replacement, but you might be lucky that it is just 'stuck' since you are not able to click it.
If you are comfortable, open it up and try to take a look at it - Otherwise most repairshops would likely give a free estimate
Bewertung 0
Antwort hinzufügen
Carsten wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 341
