Zum Hauptinhalt wechseln
Der iMac Pro ist Apples bisher leistungsstärkster iMac. Er ist mit einem 3,2 GHz 8-Core, 3,0 GHz 10-Core, 2,5 GHz 14-Core oder 2,3 GHz 18-Core Xeon W Prozessor ausgestattet. EMC 3144 / A1862 (ID iMacPro1,1)
Can the RAM on these computers be upgraded?
The additional cost to get the 128gb of RAM on this system is astronomical. If I buy one with the default 32gb RAM, will I be able to crack this thing open down the road and install 3rd party RAM if I want to expand?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 19
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Yes, it can:
Standard RAM:32 GBMaximum RAM:128 GB*
Details:*Apple reports that this iMac Pro supports "up to 128 GB of quad-channel 2666 MHz DDR4 ECC memory." By default, it ships with four 8 GB memory modules. At the time of purchase, Apple also offers to configure this model with 64 GB or 128 GB of RAM for an extra US$800 or US$2400, respectively.
Here are the kits available from OWC to do a RAM upgrade:
https://eshop.macsales.com/upgrades/appl...
War diese Antwort hilfreich?
Bewertung 6
RAM may be upgraded, but it is not "user-accessible". You should firstly disassemble display to get access, and of course you lose your warranty
Bewertung 2
2 Kommentare:
You do not loose warranty in America, unless Apple can prove that you broke something inside it when you opened it/upgraded it.
von
Probably some sort of factory seal.
von
We'll need to wait for the IFIXIT teardown to understand more fully what is needed to replace or upgrade the RAM. I'm sure you have other questions on the SSD and general serviceability of this system. This system does not have an access door like the other 27" models.
Per Apple's notes: "The RAM can be serviced by a qualified Apple technician".
Now consider when you plan to add the RAM. Most people won't need more than 32 GB. Which gets into the systems warranty and if you void it by doing it your self, I would hold off until the warranty has expired. If you are doing this sooner, have Apple or Apples certified service techs do it so you don't loose coverage. Given the price of this system I would caution you doing this your self as it could be a very expensive Oops!
Bewertung 2
It would appear so. on apples site they show a glimpse of the inside.
Bewertung 0
3 Kommentare:
@captainsnowball - Its serviceable not user accessible RAM
Its not easy to get to either as you need to fully remove the logic board. Review this: iMac Intel 21.5" Retina 4K Display (2017) RAM Replacement This is about the same procedure you'll likely need to do.
von
User accessible? With apple? PFFFT no. impossible.
von
@captainsnowball - The 27" models until this one had an access panel 'user accessable'
von
Watch this video it’s the third of three but you can probably locate the other two if you wanted…It will give you a look at what’s in the box and some colourful commentary….https://youtu.be/EdwDvz47lNw
Bewertung 0
1 Kommentar:
Although they're joking around on the video , louis is an expert on apple computers and has a very successful business in new York city .
von
Yes, but take it a shop that’s done it before. 64GB of DDR4 RAM can be purchased here: https://eshop.macsales.com/item/OWC/DID2...
But the hard part is getting to the memory. Apple might have considered this when they designed the layout. It should cost you about $300-$350 in labor + $350 for 64GB of memory. Good luck!
Bewertung 0
Antwort hinzufügen
chris095 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 8,361
