Zum Hauptinhalt wechseln
iPod Classic der 6. Generation. Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarze oder silberne Vorderseite aus Metall
Why does my iPod show a red "x" in a circle?
My 80 GB iPod Classic shows a red "x" in a circle and won't go into disk mode. Does that mean the hard drive is bad? It happened when I connected it to my computer and upgraded iTunes to 9. I am using Windows XP.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 18
2 Kommentare
Can it hold a charge?
von
ipod not working fix x symbol
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Well, I believe you have a 6th gen, slim 80 GB iPod classic. If I am correct, iTunes 9.X (Whatever version) should be able to work with it. When a red X appears on your iPod screen, especially the 6th Gen classics, it is usually a hard drive failure. If it charges, you know it's not the battery. Try formatting it with Windows, then do a restore on it from iTunes. If that doesn't work, try giving it a good hand slap on the table (with the sync port pointing down to the table). I know this might sound barbaric, but the needle in your hard drive might have been displaced and needs to be realigned. Also, the hard drive cable that connects your hard drive to your logic board might be slightly loose. Doing this will help you connect. If all else fails, which I hope it doesn't, then I believe you should sell it on eBay or try to replace the hard drive. A hard drive for this model can be found here.
Replace a broken or damaged hard drive for your 80 GB iPod Classic with this part. Bild
Produkt
iPod Classic 80 GB Hard Drive
$20.99
iPod Classic Festplatte Bild
Anleitung
iPod Classic Festplattenwechsel
Schwierigkeitsgrad:
Sehr schwierig
50 minutes - 2 hours
iPod Classic Festplattenkabel Bild
Anleitung
iPod Classic Festplattenkabel austauschen
Schwierigkeitsgrad:
Sehr schwierig
War diese Antwort hilfreich?
Bewertung 48
101 Kommentare:
I love the "bash it against the table" solution- it's worked several times for me. 1+ vote.
von
Trey you are the man!!! I bashed my iPod classic 80gb....I had nothing to lose as I had the red X and it wouldn't restart..so I read your advise and smack! Next thing it makes this noise that I'd never heard before...like a fax modem then it's good as new! You are a champion, thanks heaps!
von
that was CRAAAZZYYYYYY!!! my iPod was whacked out and then i did the smack on the table... it made a sound like dial up internet and then i heard a familiar whirrr of the hard drive spinning properly. YEA!!!
von
How should it be smacked or on what??
von
Trey thanks very much you are clever man i did your intruccions and work so well
von
96 weitere Kommentare anzeigen
here is a "howto" video: http://www.youtube.com/watch?v=RZDYk4-kc...
Bewertung 3
somebody has to open the iPod and replace the hard drive. The cheapest way is to do it yourself and you should get away with around $70. The part is available on ebay. Here's a iPhone Repair guide on http://www.portatronics.com/guide how to disassemble an iPhone. Maybe a tech savvy friend can do it for you. If you want to pay to have a service do it for you there are third party Services such as ifixit.com
Bewertung 1
1 Kommentar:
Sorry Michael, I think you may have misunderstood the modus operandi of this website. iFixit offers no repair service of any kind, but rather provides well documented and photographed repair guides, as well as the parts necessary to complete these repairs. For example, relevant to hard drive failure of this particular iPod model, there is this guide and these parts.
von
If Your iPod Displays a Red "X" Icon:
http://support.apple.com/kb/TS1463
1. Put your ipod into disk mode
If you don't know how to put your ipod into disk mode:
http://support.apple.com/kb/HT1363?viewl...
2. Connect it to your computer
Bewertung 1
1 Kommentar:
and what if i cant transfer it into dsik mode at all... tried 5 times now!
von
Antwort hinzufügen
Rita4259 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 86
Letzte 30 Tage: 397
Insgesamt: 225,094
