Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
Frage geschlossen
changing to wd 1tb hdd
hi guys
i´ve heared that you can upgrade the hdd up to 1 tb now. the new wd do have 1tb 2,5 and a installation height of 12,5mm. as i readed on several blogs and forums it should be now possible to build in hdd´s with this height.
sdomebody experencies with it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
9 Antworten
Gewählte Lösung
For the record here is a 1TB drive (12.5) that OWC states will fit in a MacBook Pro unibody. Ralph
http://eshop.macsales.com/item/Western%2...
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
DFM had it right. Ralph
von
iFixit doesn't seem to offer any 1TB drives for it, and says on both the mid and early 2009 version pages the max you can get is 500 gb.
Bewertung 1
Go for it! I installed the WD10TPVT a couple of months ago in my 17" Unibody and it works perfectly! It fits perfectly and was an easy upgrade.
Bewertung 1
This computer is compatible with 12.5mm drives. However, my recommendation would be to look for an AF (Advanced Format) drive to do the upgrade.
AF drives have larger per platter capacities, so these drives don't need to be as thick to have the capacity that is equal to a pre-AF 1TB drive. Many of the AF 1TB drives are 9.5mm, so these drives will fit in your computer without having to worry about the thickness of the drive.
Bewertung 1
but thats not true you do get the first 1tb hdd´s.
Bewertung 0
according to this article at TUAW, the 12.5mm high drives such as the WD 1TB Scorpio are too thick to fit in any of the unibody Mac laptops - although such a drive would fit in the previous generation 17" MBP. this info apparently comes from Other World Computing, a reliable vendor of Mac hardware upgrades
Bewertung 0
Fitting 12.5mm hdd in 17 inch Unibody MBP is not a problem at all. I'm writing this from my MBP already upgraded with WD 750GB which is 12.5mm thick also. So, 'that article' is just not true.
Bewertung 0
If you called the apple support they would tell you if you want to call the number is
U.S. iPod and Mac technical support:
(800) APL-CARE (800-275-2273)
Canada technical support:
(800) 263-3394
Bewertung 0
Turns out it is
Bewertung 0
1 Kommentar:
Editing this is great, but it's best to just delete your own answer when you realize it was incorrect.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 7,140
