Zum Hauptinhalt wechseln
Der Xbox One Wireless Controller Modell 1697 wurde 2015 veröffentlicht. Er ersetzte das Controller-Modell 1537 und behob einige der Probleme, die bei diesem auftraten. Der Controller Modell 1697 verfügt über eine integrierte 3,5-mm-Kopfhörerbuchse, die die Kompatibilität mit den meisten Headsets von Drittanbietern ohne einen zusätzlichen Adapter ermöglicht. Dieser Controller wurde eingestellt und durch das Modell 1708 ersetzt.
Does anyone make a MicroUSB cable that works well with this controller
I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.
While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.
The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)
Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
How about soldering in a braided wire? https://www.amazon.com/dp/B012A1221Q/ref... just chop the micro USB connector off the end of this one.
Update (02/01/2018)
Actually, Here's a braided one for xbox 1 controllers. why braided? from my experience it extends the life of my apple cables soooo... https://www.walmart.com/ip/Microsoft-Xbo...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@nick not sure or not if you get a notification for updates, so here's this.
von
I'm not sure if Microsoft does the same thing they do with the Elite cable as they do with the Play and Charge cable. I doubt it, but I've never seen anyone with one yet to verify that.
von
The ones on monoprice.com are really good and come with a lifetime warranty.
Bewertung 1
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 3,068
