Zum Hauptinhalt wechseln
Das LG G4 kam Anfang Juni 2015 auf den US-amerikanischen Markt, wie immer mit dem Fokus auf High-End Technologie und einem raffinierten Design, was es als Permiumsmartphone aus der Masse herausstechen lässt. Jede Version des Telefons hat eine unterschiedliche Modellnummer, abhängig davon, ob es von einem Telefonanbieter oder LG selbst als US Unlocked oder Internationales Modell verkauft wurde.
74 Fragen Alle anzeigen
Phone not accepting Sim Card
So my old LG G4 (H815 Factory Unlocked) isn't playing ball with my Boyfriends 3 Sim. The phone is confirmed Unlocked and I've been able to use my GiffGaff sim in the phone which further confirms it's unlocked. However it refuses to accept a 3 sim (Both my new 3 Sim; his and one from the store)
I've tried factory resetting the phone a number of times, rebooting, opening it up and inspecting the prongs. Nothing; any advice?
I've also fiddled with APN settings and LTE/GSM settings.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
While this is likely a hardware issue with the cellular radio, try another SIM card. It doesn't need to work, so use a dead SIM that's been deactivated or an expired T-Mobile SIM. The other option is to buy a prepaid SIM card kit from Net10 or Tracfone since the phone isn't carrier locked.
If you continue having issues, there's a problem with the cellular radio or SIM slot. If you're comfortable with board level repair, you can try to troubleshoot further. f you are not, then you're going to need a new motherboard.
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
See, I failed to mention that it did detect the sim once, it had a data value but no connection. I think a motherboard replacement may be in order though.
von
That could mean the SIM is inactive. If you know with 100% certainty it's active then it might be the board.
von
Sim is 100% active; it's been working in another phone. Sounds like a mainboard issue
von
Sim card not working other phone simcard is working
von
Antwort hinzufügen
Finlay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 7,058
