Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
MacBook Pro hardware issue?
Wondering if anyone can help,
I have a Mid 2014 13” MacBook Pro with the new style PCIe SSD, recently it started freezing/crashing and when reset it wouldn't detect the SSD (flashing folder with question mark),
I assumed the SSD was dying and purchased a new one, which worked for a few minutes on replacing and started doing the same thing, I think the actual PCIe port may be dying, as i stuffed a folded piece of paper above the connector before closing the case and it worked for a few hours, but started crashing again.
Does anyone have any ideas besides replacing the logic board?
Really don’t want to do this as I already had to pay for a new SSD
This is the original SSD, i can post a picture of the new one later on today, it looks identical but it says samsung on the chip
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
Are both Blade SSD's the custom Apple drives or something else?
von
Yeah the small ones i think the port is called pcie x2
von
Can you take a picture of the labels on the SSD's so we can read them and the connectors so we can be sure here. Here's how to post them: Bilder zu einer vorhandenen Frage hinzufügen
von
Hello, I think that now I have exactly the same problem with you and I did the same things as you did in this post. Did you manage to reach a solution by chance ?
von
No im afraid not, im pretty sure the port has failed and the only solution is to replace the motherboard, its the last time i buy anything made by apple, they make it uneconomical to repair so you have to buy a new one, look into the lenovo x1 carbon, thats what i bought as a replacement
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
For logic board failures on this model I recommend contacting Apple directly at 1-800-MYAPPLE and requesting a “Depot Flat Rate Repair”. The cost for this in Texas including FedEx overnight shipping and tax is $357.
Due to the expense and difficulty finding parts, replacing it yourself when this service is available isn’t prudent.
If the machine has not received liquid damage of impact damage you are eligible for this service.
Total time from call to back in your hands is four days. Make a Time machine backup if you cam as you will lose you data.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Ish wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 128
