Zum Hauptinhalt wechseln
Veröffentlicht im April 2010 / 2,4 GHz, 2,53 GHz Core i5 oder 2,66 GHz, 2,8 GHz Core i7 Prozessoren
590 Fragen Alle anzeigen
Will this capacitor work solving Kernel Panic
Hi guys!
I'm looking for an aluminum capacitor to replace C9560 on a 820-2850-a motherboard and looking on internet, I foun this:
https://industrial.panasonic.com/ww/prod...
Will this work?
And another question, when looking for an smd component, are the specs on the schematics all I need when shopping for components? For example, if I'm looking for a capacitor and the schematics indicates voltage, % and capacitance, am I completely safe if using a capacitor that matches this specs only?
Have a great day! :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@andresteare your capacitor is a 330 UF 2.0V 20% Poly-Tant capacitor in a B2 package. Yes the one in your link should work given that the physical dimension fit. “are the specs on the schematics all I need when shopping for components “ Yes for most of it you are okay with going by the values. Check on here for what the different types of capacitors do and where they are used etc.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
in this video --> https://www.youtube.com/watch?v=NfY6vTQt...
the guy makes the capacitor fit, and he shows how he does it in the video.
Question?
Do you guys do this type of fix ?
von
@tonyd20570 iFixit does not do any repairs. Here you are being empowered to do your own. You can get advice, guides, suggestions and assistance to fix things yourself.
von
Antwort hinzufügen
Andres Teare wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 1,865
