Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Runnig slow on battery support
The MacBook Pro I have, gets very slow when running on battery, the cursor gets really slow.
So I’ve been reading a lot and I identified my model (MacBook8,1)
I erased the plist file in the kext file that the tutorial shows.
Then when I reset the system it gets better, so I believe that I’ve fixed the problem,
BUT, when I run Serato DJ 2.0.3 off of battery power the processor gets very high processing, and with the MagSafe connector plugged in it gets down to OK.
What can I do??
I also run the app Dan said coconutBattery and shows this:
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
First I would check the battery to see how much life is left in it. Download this great free app: CoconutBattery. Paste a screenshot of the main window so we can see it here Bilder zu einer vorhandenen Frage hinzufügen
I would also check the energy settings within the Energy Saver control panel to make sure the settings are correct. I would enable the show battery status in menu bar setting I would also make sure not to put the disk into sleep mode when on battery given you’re running a DJ app here. I hope you’ve got plenty of son de Cuba (Buena Vista Social Club) I love Ibrahim Ferrer’s Nuestra Ultima Cita for us older folks!
Being in Cuba it can get quite hot and humid ;-} So you may need to clean out the dust buildup inside and the fan & heat sink. You may need to also clean and apply a fresh coat of thermal paste on the heatsink. As I’m also suspecting your system may be slowing down as it’s overheating.
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro (13 Zoll, Ende 2011, Unibody) Kühlkörper austauschen here we are only cleaning it.
You might want to download this app: TG Pro it will allow you to monitor your systems temps so when the system slows down you can see if it’s overheating.
MacBook Pro 13" Unibody Late 2011 Kühlkörper Bild
Anleitung
Schwierigkeitsgrad:
Mittel
45 minutes - 1 hour
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
No, no soy cubano, ¡me encanta la música!
von
Thank you Dan, I will download the apps. I already make a clean up of the MBP and replaced the thermal paste. I love music too, but I´m not the Dj, it´s a friend of mine and the MBP is his. I´ll post the photos once I download the app, the Internet in Cuba sometimes is very slow. Thank You!
von
The coconutBattery App shows status Good
von
Can you paste a screenshot of the main window so I can see the other data. As the cycles and the voltages are what we need to focus on.
von
could this be a problem in the SMC chip??????????????
von
1 weiteren Kommentar anzeigen
First Try resetting the SMC, If this doesn't work then I would suggest replacing the battery. Just make sure not to buy a cheap battery off of eBay; I would recommend the cheapest battery being $40.
I replaced my old battery with this one from Amazon.
Bewertung 0
Antwort hinzufügen
Luis Anniel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 106
