Zum Hauptinhalt wechseln
Das Android-Smartphone Tecno Y3s wurde im April 2015 von Tecno veröffentlicht.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Ist dies eine gute Frage?
Bewertung 20
2 Kommentare
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
von
Sir, my mobile battery is very weak, what should I do to get it fixed?
von
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
War diese Antwort hilfreich?
Bewertung 3
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
Bewertung 3
To take a look on battery terminal if a well connected second to check life of battery
Bewertung 0
1 Kommentar:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
von
Phone is not power on and showing logo
Bewertung 0
1 Kommentar:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
von
My phone charging socket is not working
Bewertung 0
No problem my phone is ok
Bewertung 0
Charging my phone slow way
Bewertung 0
Antwort hinzufügen
Eric Matibila wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 3,556
