Zum Hauptinhalt wechseln
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
Broken Hinge on laptop
Hey, my laptop Acer Aspire E 15 (E5-575G) has a broken right hinge. Due to this the right hand side of the screen has separated from the keyboard. This issue is starting to create an issue in the left hinge as well as it is slowly becoming damaged aswell due to the opening and closing of the lid. If you believe you can help can you please contact me on thealexmartins@gmail.com. I am able to send pictures for further explanation.hing
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @thealexmartins ,
Here’s a link to a video that shows how to replace the hinge assemblies.
Replacement hinge assemblies are available online. Just search for Acer Aspire E 15 (E5-575G) hinge parts to get results for suppliers of the part.
War diese Antwort hilfreich?
Bewertung 1
Unfortunately it's more often the plastic that the hinges screw into that fails rather than the hinges themselves. You may be able to glue it back together with epoxy (2-part) rapid glue but you will need to add reinforcement, such as by building up the glue around the crack and/or gluing a piece of fibreglass matrix board or a piece of an old de-populated printed circuit board over the crack on the outside of the case.
Bewertung 1
1 Kommentar:
Drill holes through the lid where the original screw sockets have pulled out and reattach the hinge with screws, nut and lock washer through hinge and lid. a bit inelegant but effective and a lot cheaper than the $90 for a new lid,
von
Antwort hinzufügen
Alex Martins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 40
Insgesamt: 7,526
