Zum Hauptinhalt wechseln
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 Fragen Alle anzeigen
Is JDS-040 correct replacement for CHU-ZCT2U (or/and FJDS-040)
Controller model: CUH-ZCT2E.
1) Would FJDS -040 work if my current/existing board is JDS -040?
I can mostly found FJDS-040 which seems to be different compared to my JDS-040.
My USB charging port:
FJDS I keep finding on ebay etc.
As you can see board layout is little bit different. Would those FJDS one work?
2) On USB boards I see square with number 1 or 2 (on different board), since both are JDS-040 boards, what those means? In short, can I replace JDS-040 board ignoring those numbers.
Example:
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The FJDS-040 is also known as JDS-040 or JDS040 and should be compatible for as long main board controller is a JDM-040 which it will since your original is a JDS-040.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
@oldturkey03 Awesome, glad to hear it! Thanks for the reply and also explaining main board relation, really helps me in future, something to add into personal knowledge bank.
von
Looks like it is! According to this guide on iFixit though.
DualShock 4 CHU-ZCT2U Ladebuchse tauschen
Bewertung 2
9 Kommentare:
Thanks! Any idea are FJDS-040 still suitable ? Have not yet found any reliable source for JDS-040 boards, only see FJDS-040 being available.
von
@ajcooke01 Thanks for the link! Unfortunately they dont display bottom of the board. I noticed at ebay and amazon which includes these "JDS-040 With 12 Pin" but upon zooming they all read "FJDS-040" instead just "JDS-040". Since boards layouts are slightly different, quite confused if FJDS and JDS is considered as "compatible" with each other.
von
@coffeeod Well, I guess we are in a bit of a pickle here...
Could you link me to the board(s) you are looking at buying?
von
@ajcooke01 example when searching for jds-040 on eBay I get these https://www.ebay.com/itm/12-Pin-USB-Char..., when you look at images you noticed it's actually an fjds-040. Comparing that to my posted image (my usb charging port) board layout is indeed different
von
4 weitere Kommentare anzeigen
Antwort hinzufügen
Michael Schales wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 7,605
