Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
300 Fragen Alle anzeigen
15” unibody mid 2009 feet and screws
Hi
The shop has feet and screw sets, but not appropriate for my MacBook. Any suggestions?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hey Victor, last night when I answered this question it had listed that your machine was a different MacBook, not the MacBook Pro unibody that is listed now. Sorry about that. Refer to @mayer's answer.
I have used these exact feet as replacements for clients before and they are solid. You might find that you have to use some extra liquid adhesive and a clamp while drying. If you decide to do this, make sure to remove the bottom case cover from the Mac to ensure liquid adhesive does not drip into the internals.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here’s how to do it and the correct feet:
MacBook and MacBook Pro Unibody Plastic Feet
MacBook Pro (15 Zoll, Mitte 2009, Unibody) Füße austauschen
MacBook and MacBook Pro Unibody Plastic Feet Bild
Produkt
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks very much, just purchased the parts.
von
Hilfreichste Antwort
Hey Victor,
If you’re really picky on getting feet specific for your MacBook, you’ll probably have to do some digging on eBay or Amazon. But if you’re just looking for a quick and efficient fix, I’d buy some general rubber chair feet off Amazon or from your local hardware/home improvement store.
Here’s a few examples that i’m thinking of:
https://www.amazon.com/20-Round-Rubber-F...
https://www.amazon.com/Tenozek-Furniture...
In order for these to work, you might have to remove the remaining feet that are still intact in order for the MacBook to be level. If you want them to match the color of the case, you might even be able to find them in white. Amazon has pretty much everything…
Hope this helps
-Alex
Bewertung 2
2 Kommentare:
Thanks, good suggestion.
von
Glad I could help!
von
Antwort hinzufügen
Victor Caamano wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 85
