Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
iPhone 7 stuck on apple logo after screen replacement
I first replaced the screen and got a boot loop error.
When I connected the old, broken screen it worked fine and booted properly, so thought it was the new screen that was faulty.
I ordered another replacement screen and did the replacement but afterwards the setup just stayed on the apple logo indefinitely. I thought this screen was faulty as well so reconnected the original broken screen but the same thing was happening with that.
I read through a few forums saying it may be the camera flex cable that is broken, so I disconnected that and there was no change, still staying on the apple logo.
I have now bought another camera flex cable to double-check if that’s what is causing the error (I may have broken it during one of the replacements), but no success.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
I had this happen on an iPhone 7 Plus that I was working on. Double Check the connections from the screen going to the motherboard. Apparently one of the connections on the screen was not seated correctly and was causing the phone not to boot.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I have pressed down reasonably hard on all the connections but that hasn't seemed to work.
von
If all the cables are connected correctly, I’d try a new front camera flex just to be sure. 7s boot loop for pretty much any little issue, just try a couple things if you have parts around
Bewertung 0
1 Kommentar:
I have already tried this with no success.
von
Did you disconnect the batter before repair and connect the battery last after the repair? This can happen if you have damaged the home button flex. Maybe the first screen was faulty but when transferring components to the new screen then you may have damaged it the home button flex. Another reason could be you somehow damaged the battery when repairing the screen however that isn’t very likely to happen.
Bewertung 0
1 Kommentar:
As I did the transfer between screens a few times I may not have disconnected the battery every time.
Also, before I bought the newer replacement screen I did manage to get the original screen to work without the home button flex connected, so I don't think it is that.
von
Antwort hinzufügen
James Lloyd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 135
