Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
Low boost clocks and high temps in Cinebench
I’ve got A1398 Late 2013 with 2.6ghz i7-4960HQ. Thermal paste apparently wasn’t swapped it’s entire life. In Cinebench it was reaching 95-100 degrees and 2,8 - 2,9 clocks. CB score - 540 or even lower.
I changed the paste with Cooler Master V1 IC Value. And got… 95-100 degrees and 3.0 boost clocks AT MAX. CB score 580 0_0
This model must give about 640! What the heck is that? I didn’t make any nooble mistake I bet, I did everything right. I even reapplied the paste to be sure it’s not my fault. Nothing changed, it works slower than it must and even gets hot while FF playing video.
What could be? Never stumbled upon anything like that
Before CB:
While second run launched instantly after the first
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Lets get a better view on things here, install this app TG Pro its one of the better monitoring apps. Wen the system is idle take a snapshot of the main window, make sure you grow it so all of the sensors and fans are visible. The do a second snapshot capture just after running Cinebench. Post both here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Done
(I have to write something to make my comment longer so the site passes it :D)
von
Your cool ;-}
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
OK, I think I see the issue. Note the heat pipe Outgoing Air sensors are very low in comparison to the CPU temps when you are stressing the system.
So the heatsink has failed! The coolant within the tube has leaked out. You’ll need to replace it. Keep in mind there is two versions of this system. The IG - Intergraded Graphics (Intel Iris) & DG - Dual Graphics (Intel Iris and AMD GeForce GPU. Make sure you get the correct heatsink.
The only way I know of to tell if yours is truly dead is to use a good weight scale that can measure the subtle difference of a wet Vs dry heatsink.
This part attaches to the processor and helps dissipate heat. Bild
Produkt
MacBook Pro 15" Retina (Late 2013-Mid 2014, Integrated Graphics) Heat Sink
$19.99
Produkt
MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink
$19.99
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Oh God. Couldn't expect it may fail at all. Especially because it has absolutely no signs of possible damage ore any interference at all.
The first time I face such thing :I'm ordering a replacement, but are you sure no other issues may cause it?
von
The reason for two snapshots was to isolate the issue. I've replaced over six in the retina series.
von
Thanks for your help!
von
Hi!
Finally I’ve got my new heatsink. And, you know… NOTHING CHANGED! Everything is the same, temps are high, clocks are low.
What’s the heck is wrong??
Bewertung 0
1 Kommentar:
Applied liquid metal - no results. Even on highest fan speeds!
von
What I found out:
In Windows 10 it's FASTER THAN IT SHOULD BE! 665 CB instead of 640 intended. Probably, because of LM on CPU
But it still throttles way lower in ANY MacOS, Mojave nor High Sierra, with or without custom fan control, on automatic nor full fan blast.
I've ran ASD testing and everything is fine
What da heck?
Bewertung 0
Antwort hinzufügen
Anri wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 198
