Zum Hauptinhalt wechseln
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
781 Fragen Alle anzeigen
Disk won’t eject. Motor turns on but nothing happens.
I put a game in to play and when I wanted to change games, I properly quit the current game and hit the eject button and I heard the disk drive door open, the motor kicked on and sound like it was ejecting the disk but nothing happened. How can I fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Do you have the fat, slim or super slim PS3? Model Number?
von
I have the slim. Model number CECH-3001B
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This link will show you how to manually remove a disc from a PS3 Slim.
If that doesn’t work, here is an alternative method that will void the warranty, if it’s still under one.
You may want to look into replacing the drive if you do end up taking the PS3 Slim apart.
Here is a guide for replacing the drive. And this is the drive you would need.
Post here again if you have more questions.
PlayStation 3 Slim Blu-ray Laufwerk Bild
Anleitung
PlayStation 3 Slim Blu-ray Laufwerk austauschen
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
PlayStation 3 Slim Bild
Anleitung
PlayStation 3 Slim - Manually Removing Stuck Disk
Schwierigkeitsgrad:
Mittel
20 - 45 minutes
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you for the help
von
Hilfreichste Antwort
I've heard that over time the rollers in the disk drives can become worn out. You might need to take the disk drive out and see if that might be the case. They can also just be really dirty so you might just clean them if they. There should be plenty of guides online for this. Here's an iFixit guide showing how to remove the drive PlayStation 3 Blu-ray Laufwerk ersetzen
Bewertung 1
Antwort hinzufügen
williameaton50 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 47
Insgesamt: 4,028
