Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
411 Fragen Alle anzeigen
Why does my xbox turn off after 1 minute with no display?
I started my xbox one up one day and it only stayed on after a minute, nothing on the display showed up and my controllers refuse to pair with their blinking light showing. Even holding the sync button on the xbox doesn't do anything. My fans are spinning. The only thing that sounds out of place maybe is that the hard drive makes a noise every 20 seconds like it suddenly stopped and started again. I opened it up and removed all dust inside which were minimal amounts. Any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
These usually come with a Seagate Mobile HDD, these commonly go bad after 1-2 years. If it’s making a ticking pattern the hard drive will need to be replaced. One way to confirm it’s the HDD is to just plug in any 2.5” laptop sized hard drive and see if you can get display at least.
Here are the two guides required for replacing the HDD on the One S:
Xbox One S Festplatte austauschen
Firmware auf Xbox One S installieren
Xbox One S Festplatte Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
Xbox One S Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
30 minutes - 1 hour
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
That was it, thank you!
von
Anyone in the future who might have this problem, my hard drive ticked once per second when it was trying to boot. I switched it to a laptop hard drive showed the display and switched it back to my old hard drive and booted up fine, guessing it's a sign to get a new hard drive. Thanks man. You saved my week head ache and a lot of money.
von
Exactly what i was dealing with. thanks for sharing the question and thanks for the answers.
Bewertung 0
Antwort hinzufügen
Michael del wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 829
