Zum Hauptinhalt wechseln
Gray display, everything work fine with external monitor
Hi everyone, i've got a problem with my macbook pro: the computer itself works fine but the display show only a gray screen (backlight work fine too), and i'm forced to' use an external monitor.
Do i need to repair the whole LCD or just the cable?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
Was there a history to this failure? Does the screen do anything when moved up and down?
von
well, some time ago I've had problem just with the upper part of the screen, it began to shade colours to white, while the lower part remain "normal". then if i pressed on the side of the screen for a couple of time it returned ok.
One day i just switch on the computer and the screen was all gray, and did not show anything also if i tried to press the borders... That'it.
Any idea?
Thanks a lot for your answere!
von
hi guys!
So, today i've replaced the cable arrived from Ifixit... nothing happened!!!
I argue that i'm forced to replace the whole display.... it isn't?
Does anyone have got other solutions? Other cables that i may replace before I'll buy another display?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If you're lucky, the LVDS cable (video cable) is only disconnected from the LCD socket or the cable is faulty. That's the first thing you should check by opening the LCD panel.
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
Thanks for your answer, i've checked the LVSD cable and was connected to the LCD, so hopefully it is faulty.
Now i've got another problem: after I've opened the LCD panel the monitor show me a white screen when I start the computer, then a black screen, also while i'm working whith external monitor, and backlight doesn't function anymore...
Did I unexpectedly broke the LED Driver Board too?
Is the cable you're talking about, LVDS cable, the one show at the following link?
MacBook Pro 15" (Models A1226/A1260) Display Data Cable
Thanks!
von
[verlinktes Produkt fehlt oder ist deaktiviert: IF185-133]
Thanks!
von
In the preferences on my computer, I've noticed that no monitor was detected:
NVIDIA GeForce 8600M GT:
Modello Chipset: GeForce 8600M GT
Tipo: GPU
Bus: PCIe
Larghezza Lane PCIe: x16
VRAM (totale): 128 MB
Fornitore: NVIDIA (0x10de)
ID dispositivo: 0x0407
ID revisione: 0x00a1
Revisione ROM: 3175
Monitor: <---------------------------------------------
show connector::
status: No display connected <------------------------------------
von
Yes this is the cable you need to replace.
von
Un-accept the answer so others will look at your question again. When it's turned on, hold a flashlight at an angle to the screen and see if you can see the desktop. If this is the case then the inverter or its cables or connection are not working. Please let us know.
Bewertung 1
hi guys!
Bewertung 0
Antwort hinzufügen
Matteo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 3,792
