I don’t think you understand just what a fusion drive is. It is a combination of a SSD drive and a standard SATA hard drive.
Standard Storage:1 TB (Fusion)Std. Storage Speed:N/A
Details:This model has a 1 TB "Fusion" Drive, which combines a 32 GB SSD and a 1 TB hard drive. It has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive and a PCIe connector for the SSD.
At the time of purchase, Apple also offered a 2 TB "Fusion" Drive for an extra US$200 (128 GB SSD and 2 TB hard drive) or a 256 GB, 512 GB, or 1 TB SSD for an extra US$100, US$300, and US$700, respectively.
Pre-Installed MacOS:X 10.12.4 (16F2073)Maximum MacOS:Current
Your 2008 iMac uses these systems:
Pre-Installed MacOS:X 10.5.2 (9C2028)Maximum MacOS:X 10.11.x*
So the 2088 will not boot from the system on the 2017.
The drive could be hooked up externally and you recover your data off it, then reformat the drive, install a maximum system of 10.11,
You can now boot from it to test it out by holding down the option key on start up and selecting it. If it works OK, you can then install the drive in your 2008 machine.
iMac Intel 24" EMC 2134 und 2211 Festplatten austauschen
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
