Zum Hauptinhalt wechseln
{A1706 / EMC 3071}—Veröffentlicht im Juni 2017. Dieses 13" Macbook Pro ist mit Kaby Lake Prozessoren bis zu 3,5 GHz Core i7 mit Turbo Boot bis zu 4,0 GHz ausgestattet.
276 Fragen Alle anzeigen
Should the fans run all the time on a 820 00239
I got sent a mac which had the U5860 temp sensor torn off along with all the pads on the board. It would take ages to boot if at all and the fans where spinning flat out. I turtled the chip, ran 9 jumpers, masked the chip and jumpers and installed the board back into its housing. I have tried all the resets.
·         The mac boots straight up but the fans do not spin
·         When I run the diagnostic check it will spin each fan separately
·         The diagnostic results show no problems detected.
We live in a cold climate I have tried playing YouTube videos to get the fans to spin but they don’t. The CPU doesn’t feel extremely hot. Am I missing something or is it normal on these newer macs?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Unless you are located on Antarctica right now, your not is a cold enough climate to worry about SMC and the thermal sensors ;-}
What does TG Pro tell you? Post a snapshot of the main window (you'll need to resize it to get everything in) Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks Dan. TG-PRO displayed a message saying. “This model of mac will safely turn the fans off when the CPU is running at low capacity.” That’s all I wanted to know.
von
@imicrosoldering - Thats good! Sounds like you good to go! Don't forget to accept the answer.
von
Antwort hinzufügen
Chris Stables wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 270
