Zum Hauptinhalt wechseln
Die Nintendo Switch ist eine tragbare Spielekonsole, die auch mit dem Fernsehgerät verbunden werden kann. Sie wurde am 3. März 2017 veröffentlicht.
706 Fragen Alle anzeigen
Missing resistor near charging port
Hi.
Sorry if this has been asked before or if I'm posting in the wrong section.
Just wanted to ask if anyone can tell me what the 2R2 634f is what the value of the resistor near next to it is. I've circled them in purple.
Pic attached.
Thanks
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
It is a Signal Transformer, some call it a power inductor. The one you need is part # SCIHP0420TB-2R2
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks Ric. Would you happen to know the value of the resistor next to it?
von
2R2 634F is NS motherboard power inductor Big coil components check this http://egamephone.com/index.php?rt=produ...
Bewertung 2
3 Kommentare:
My switch stopped charging, the battery was draining, and the charging symbol was there, but the battery kept draining. I bought a battery to replace the old one, and when I opened up the switch, this piece was just laying there. What would cause it to break off, and is this the reason my switch isn’t charging?
von
@Michael - Same here. Came in not charging or powering on. Powered up with an new battery and would charge if the battery had some juice. Would not charge a dead battery though. I noticed the 2R2 inductor had come undone. Soldered another one from a dead Switch mobo and it works fine now.
von
@ACE How did you manage to solder another inductor on with the pads on the underside? Did you have to use hot air?
von
There is no photo attached.
Bewertung 1
1 Kommentar:
Sorry must have missed it. Its uploaded now.
Thanks
von
Antwort hinzufügen
email ko wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,866
