Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
561 Fragen Alle anzeigen
Which SSD upgrade should I go for
So, i am about to buy the SSD upgrade for my mac and i have two choices...
OWC Drive with Read of 501mbs and Write of 503mbs at £186. This drive is made by a company.
https://www.thebookyard.com/product.php?...
or
Fledgling P12 with Read of 473mbs and Write of 465mbs at £141.15. This drive is not made by a company per say but is the result of crowdfunding for more affordable drives for the macbook pro.
https://www.ebay.co.uk/itm/1TB-Solid-Sta...
So my question is this. Do i go with the cheaper one or will the 28mbs / 38mbs make enough of a difference on my mid 2012 retina that it would be worth paying the extra £45
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I'd go for the P12. I know that 3rd party SATA based SSD adapters and SSDs are fine. It's the PCIe based one that is unreliable.
von
What is the warranty on the cheap one? I just wrote the company to try to get more information on them.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It shouldn't make a difference, my bigger concern is the quality of the product between the two and not so much the write speed. I sincerely doubt you will notice any major difference between the two so if you consider them both a quality product, go with the cheaper one.
War diese Antwort hilfreich?
Bewertung 1
You’re not going to notice the difference. I know some people do not like OWC drives but I personally use then in my machines and have zero issues. Just be aware if you plan to use an adapter you may run into fitment issues. Good Luck!
Bewertung 0
Antwort hinzufügen
Skyler Chie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 64
