Zum Hauptinhalt wechseln
Das OnePlus 6T ist ein Android Smartphone von OnePlus. Angekündigt wurde es am 29. Oktober 2018 und erschien dann am 6. November 2018.
I Accidentally scraped my battery
I accidentally scraped my phone battery a couple of times while removing the back panel of my OnePlus 6T. Should I replace the battery or will this battery still work like this? It is not punctured at all, just has some grooves on top
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
You should never use damaged batteries but you can add a picture of it so we can see how damaged it is.
Bilder zu einer vorhandenen Frage hinzufügen
von
Picture added to the question. If I may add, I have already charged and gone through 3 cycle charges and the battery does not overheat or anything. Would this still be considered heavily/dangerously damaged?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Even if it works fine, replace it. Normally I wouldn’t be concerned about a very, very light surface scratch but these are deep enough to warrant replacing it. Softcells have zero protection like old modular ones in a metal case.
It may be fine, but it’s not worth the risk since softcells are so easy to damage. The battery can be found here.
Replace a BLP685 model battery compatible with OnePlus 6T and 7 model smartphones. 3610 mAh. 3.85 Volts (V). 13.89 Watt Hours (Wh). Bild
Produkt
OnePlus 6T and 7 Battery
$14.99
War diese Antwort hilfreich?
Bewertung 1
Never used damaged batteries in devices, especially if you get the smell of rubbing alcohol or burnt skittles as other people have described it.
Bewertung 0
2 Kommentare:
I just added a picture To my question. No smell is coming out of it. I'm just worried if those grooves may be considered dangerously damaged or not. Can I please get your feedback on it?
von
Yeah I'm concerned about those grooves. I would get a replacement, it's not worth the potential third degree burns.
von
Antwort hinzufügen
Alberto wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 790
