Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 13" MacBook Pro Retina Display, Modell A1502, bietet fifth-generation Intel Core i5 und i7 Prozessoren der 5. Generation und führt den Force Touch Trackpad ein.
1185 Fragen Alle anzeigen
I was replacing the battery... but I knocked off 1 of 2 silver circles
I was replacing the battery, following the ifixit guide...
I was Upto step 9 and
but I knocked off 1 of 2 silver metal circles just above battery connector in the middle.
what do these 2 metal circles do?
should I super glue it back on?
or does this metal component need more attention (like a soldering iron)?
what do I need to do?
Update (05/25/2020)
Thank you for your replies.
so based on the image and information provided…
can I glue this back to the board?
or does this need soldering?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Let's see what you got post an image of what you knocked off and the place they came from Bilder zu einer vorhandenen Frage hinzufügen
Did you follow this guide: MacBook Pro 13" Retina Display Anfang 2015 Akku austauschen?
von
@o07bond - OK, you broken off the mounting studs. Let's get a pic of yours so we have a better idea how they came off. Focus on the mate surfaces of the studs and the logic board location.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It looks like basically a nut that you can put a screw into it.
Update (05/25/2020)
It will need to be soldered down to secure it.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
It's a logic board standoff (stud). It offers a threaded mount point to anchor something, in this case a metal cover.
von
@danj
Thanks the replies Dan - it definitely has threads inside of it :)
I think the metal shield goes over it
In terms of getting it to stick back down...?
Thoughts
von
von
You will need to get some acetone to clean off the surfaces and then carefully screw in the screw back into the plate and the stud so the plate sits correctly. then carefully screw in the other screw which holds the plate to the second stud. Now ever so carefully lift the edge of the plate just enough (hairline) so you can drip a drop of Cyanoacrylate glue (a.k.a Krazy Glue)
There is no solder used here.
Bewertung 1
Antwort hinzufügen
Josh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 69
