Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Ist dies eine gute Frage?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Anleitung
Schwierigkeitsgrad:
Leicht
5 - 10 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
1 hour
Anleitung
Schwierigkeitsgrad:
Mittel
9 - 15 minutes
War diese Antwort hilfreich?
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 54
Insgesamt: 1,911
