Zum Hauptinhalt wechseln
Erschienen im Oktober 2014; Android-Betriebssystem v4.4.4, bis zu v5.1; 32/64 GB Speicher und exklusiv bei Verizon Wireless.
Charging port not snug
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
von
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
von
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with Motorola Droid Turbo Akku Austausch
May be it helps.
von
Einen Kommentar hinzufügen
1 Antwort
You can take it to a technician for repair. Lose charging socket is a common thing and very easy and cheap to fix.
Do that before occupying yourself with installing new parts. You may not have to.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Robert Bruns wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 303
