Zum Hauptinhalt wechseln
Die Neuauflage vom April 2014 von Apples MacBook Air 11" erhielt aufgefrischte Dual Core i5 und i7 Haswell Prozessoren und eine leicht verbesserte Akkuleistung.
Yellow Vertical Line and how to resolve it
My MacBook Air's (early 2014) screen suddenly started to get one thin yellow vertical line in the middle of the screen; from top to bottom (Catalina).
  • When I did a screenshot, the line doesn't show
  • I did a hardware test and no issues found
  • PRAM and SMC reset doesn't resolve the issue
  • The line shows even on safe mode
  • Most unfortunate thing is that there is NO nearby Apple Authorized Service Provider to send for evaluation (plus its pandemic so it's not easy to travel far)
Hope someone can provide an answer on what possibly I can do.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
andrea bagani without seeing this line and only going by your description, this sounds like a Tab error. This is a fault where the ribbon cables from the LCD driver board to the LCD screen come loose. The only real option to fix this would be to replace the screen. There are companies out there that perform TAB repairs but those cost more than a new screen. MacBook Air 11" Anfang 2014 Displayeinheit austauschen
To verify this, you can post some images of what the screen shows with your QUESTION. Bilder zu einer vorhandenen Frage hinzufügen
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
MacBook Air 11" Early 2014 Displayeinheit Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
andrea bagani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 61
Insgesamt: 1,537
