Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Problems with screen after long time not using
Had it lying around for about 1~2 years. After charging up and open back the screen turns into some water-ish damage almost entire screen while the edges still looked normal.
Is the screen panel damaged? Or is it some steam trapped between screen panel and glass panel?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
You'll need to plug in an external monitor to be sure you don't have anything deeper.
If you are able to get it going enough I would also check your battery as it likely needs replacing, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I have seen this before; unfortunately, your LCD has suffered permanent damage. I can’t give you an exact reason why this happens, as there are many, but in most cases, this can be attributed to either too much heat or pressure on the display. If this machine was sitting somewhere that gets a lot of sunlight, or stacked beneath other items for a prolonged period of time, this problem will develop.
You will need to replace the LCD or the entire display assembly (whatever you’re more comfortable doing).
Sorry for the bad news.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Lee Han Chang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 79
