Zum Hauptinhalt wechseln
Modell A1989, EMC 3358. Das bisherige Design wurde aufgefrischt, die Auswahlmöglichkeiten für die Prozessoren und die Materialien der Tastatur verbessert. Erhältlich in Silber(Silver) und Grau (Space Gray) . Erschienen im Mai 2019.
134 Fragen Alle anzeigen
Replaced MacBook screen: experiencing ghosting and horizontal lines
I bought a replacement screen for MacBook Pro and installed it (using the guide on iFixIt). Everything worked fine for the first 4 days. The problem isn’t consistent. If the computer is off for a few minutes the screen will start with no issues. Overtime ( 3-5 minutes) it will develop horizontal lines, ghosting, and then freeze altogether.
The screen display in the following videos is mirroring (for reference).
I have tried:
  • iOS Upgrade
  • Turned on in safe mode
  • Reset PRAM
  • Reset SMC
  • First Aid on disk utility
  • Apple Diagnostic from startup
None have identified or rectified the problem. I’d love to identify if this is a problem with the screen that I bought (ebay) or a hardware problem caused during installation, or a software/hardware interface problem.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is no settings or alternations within the OS to fix this as its a defective display assembly! You’ll need to return the display to the seller to get a replacement, hopefully its better.
One of the risks buy online is dealing with jobbers (people you buy loose items and resell them) as you just don’t know the source is someone dumpster diving for rejects or patch working a few displays into one working unit (a common way things are done in China).
Sorry ;-{
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Not what I wanted to hear, but what I needed to hear. Thanks Dan.
von
Antwort hinzufügen
Shona wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 797
