Zum Hauptinhalt wechseln
Released in Feb. 2018, it is the newest light-weight 14-inch HP Chromebook with a built-in Chrome OS and a 7th gen Intel Celeron processor N3350.
4 Fragen Alle anzeigen
How can I reset a managed chrome book back to factory?
Hello, I picked up a chrome book from a recycling center. Bought it for the screen. Turns out the chrome book is newer than the one I was using. I now use this one but cant seem to find a way to remove the system manger.
''”Your Chromebook is manged by __________.ORG” ''I’ve done a power wash and reinstalled the OS. *Please help me remove the managed system so that I can use it and manage it myself.* Thanks!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Just confirming you did this (from google support):
Factory reset your Chromebook
  1. Sign out of your Chromebook.
  2. Press and hold Ctrl + Alt + Shift + r.
  3. Select Restart.
  4. In the box that appears, select Powerwash. Continue.
  5. Follow the steps that appear and sign in with your Google Account. ...
  6. Once you've reset your Chromebook:
If so then this question has already been answered if you searched the forum. Please do that next time so that it’s not a repost of something already answered.
but it’s also possible you have a newer model that does not allow you to do that above actions:
My chromebook has an admin on it, how do I remove it?
If that is the case, there are two more routes you can take:
  1. Install CloudReady OS (Home Edition) onto your Chromebook. It’s a ChromeOS-clone that is designed to be run on a wider set of devices (like desktops, laptop or macs).
  2. Install your favourite flavour of linux (Manjaro or Mint Linux)
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Yes i searched and saw this answer but wasn't sure if that would work for all chrom books. Do you think it will work with HP?
von
Well Google is trying to do what Apple does and limit the ecosystem with specifications. So all Chromebooks have a certain standard setup. According to the second link, the newer Chromebooks have removed this security workaround. *IF* you are reluctant to open your Chromebook, I suggest you install CloudReady *BUT* I'm not certain if they also adhear to ChromeOS enterprise management. Never had the opportunity to try myself.
von
Antwort hinzufügen
john wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 93
Insgesamt: 4,320
