Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
561 Fragen Alle anzeigen
Keyboard backlight does not work
Hello,
I changed the motherboard on my MBPR and the keyboard backlighting does not work. Is there another cable especially for the backlighting?
The keyboard works, but the backlighting doesn´t.
Update (03/17/2021)
This is My MacBook. But I can Not find the cable…
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes there’s a small cable that connect the keyboard backlight to the logic board. It’s located hinges side to the left of the logic board. It’s very easy to forget to lift up the cable over the logic board during installation. Check the board you should see the small connector. If you don’t see the cable clipped on the connector it should be right there under the logic board.
War diese Antwort hilfreich?
Bewertung 1
Looks like you still have it tucked under the logic board!
Bewertung 0
Antwort hinzufügen
Eric Reinhardt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 53
