I want to fix a water damaged mac.
This is a hypothetical problem for a still learning mac repairman.
There are a lot of forums and help sites saying turn power off, dry out mac and cross your fingers. This forum is different.
Water damage is already done.
I know to clean off the connections on my ram with rubbing alcohol. But if that does not fix the problem, how do I go about fixing the water damaged parts?
Short of replacing the logicboard (assuming that was what was damaged) what can I do to fix the mac.
-What are the most commonly damaged parts when water is spilled? and how would you fix them?
-If the logic board was damaged. What exactly happens when water hits the logicboard and it "fries". Like what physical damage is caused and how can I reverse it?
I am skilled at saudering and not scared to go into the thick of the parts to fix the problem. I just dont know where to start finding the short.
Thank you for any hints, tips, suggestions, anything.
Ist dies eine gute Frage?
2 Kommentare
Hi, I am having the same problem. I know this thread is from about 4 years ago but if you get this, could you please help me out. My MacBook is 3 months old and water leaked and went into it and now I'm stuck with it with nothing else I can do and with everyone saying there is nothing I can do. If you get this, could you please help me out. Thank you.
von Henal Sutaria
I had the same problem. I replaced I/O with no luck. Turns out it was the batter $19.00 fix
von stephenbmorton
