Do you tend to run the battery this low? If you do you will shorten the battery life and will need to allow the system to properly charge the battery fully. Even though the Full Charge Capacity may appear full you need to leave it on the charger an additional 2 ~ 4 hours so the battery is maxed out.
Frankly, the battery does better when its within the middle 1/3 of charge. But, that will lessen the batteries run time unlike at full charge. You don’t want to not let the battery discharge so low as you’re burning it out!
So answering your question the battery is equal to Apple’s. Just don’t abuse it!
Your usage is the bigger factor and as you have a new battery your over focused on its run time instead of focused on usage and how you charge your system which is the issue here as you’ve already run through 10 cycle counts in 174 days which is excessive!
Remember Aesops fable the Hare and the Tortoise? Be the tortoise slow and even Vs the hare fast and worn out.
For a point of reference, here’s my 15” UnibodyMacBook Pro battery status
I rarely let it discharge past 1/2 point.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von Dan
Thanks, Dan. Done that and photo added
von Cal Nicklin
@Cal Nicklin - What does it look like with the charger plugged in and charging?
von Dan
added that too
von Cal Nicklin
