Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
20 Fragen Alle anzeigen
Battery not charging correctly
Hello, i bought an late 2008 macbook it runs well catalina and is still ok machine but the battery charges slowly and i get the “battery is not charging” message even though it does charge (but slowly how i mentioned before) also the magsafe light is always green. Does anyone have an idea what is wrong???
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
@danj I have updated the question.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
OK, while you haven’t pushed it past the cycle limit of 1k it’s quite old, just over 10 years! It’s time to replace it.
But lets also check your MagSafe connector on your system and make sure the charger is in good shape!
Make sure yours doesn’t look like this! And the cable is not messed up as well.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Nope, the connector isn't burned and the cable looks good too but I might try to replace the MagSafe connector and see if that helps.
von
I'm guessing that the discolouration around one of the pins, either on the mbp or the charger means it's 'fried'? My charger has the top end pin with slight discolouration and sometimes it doesn't light up properly and the battery says it's not charging. Brand new battery by the way.
Bewertung 0
3 Kommentare:
@pamdo53 - Time to replace both the DC-In board and you have a knockoff charger which damaged it from arcing! Lacking safety features, cheap MacBook chargers create big sparks
Make sure you get a REAL Apple unit directly from Apple as the ones sold on Amazon and eBay are 90% kickoffs! Apple.Com - MagSafe Power Adapters
von
Thanks. I do have a spare Apple original charger which seems to work fine. The "damaged" one has a T connector which makes me suspicious. It came with the machine.
von
@pamdo53 - Don't forget to score the answer.
von
Antwort hinzufügen
Mitch Fujiwara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 223
