Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
Home button not working after restore
Hi!
so recently I just replaced my iPhone 7 lighting cable and the front camera and now that it boots I’ve been having some problems. First, before I could get it to boot I had to restore the phone like 10 times because non of them were successful. Once I got it to boot, then I went through the setup perfectly fine up until eventually the home button stopped working. I don’t know if it’s broken or not because it was working perfectly fine so im just wondering if anyone could know the problem with it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you removed the screen but did not remove the home button the problem will be a micro tear in the flex coming from the screen to the logic board. It will be on the shortest flex at the 90 degree bend. You will need a replacement screen.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
All I did was disconnect the screen piece (as a whole) from the phone. I don’t know how it would tear because it was working after the repairs. It just recently stopped working. Also why would I need to replace the screen? Would just replacing the button work?
von
The flex that gets damaged on the iPhone 7 is the one that goes from the screen to the logic board. It has nothing to do with the home button assembly. You would have disconnected two connectors on the bottom of the logic board that go to the screen; the shortest one is the home button flex.
von
Oh ok. Thank you
von
Antwort hinzufügen
GurshaanSingh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 50
