Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Laptop dies when unplugged
I replaced the battery in this MBP just over a year ago. It now shuts off immediately when unplugged and Coconut Battery registers no battery at all.
Does this indicate a faulty battery or a logic board problem? The latter seems more likely to me, but I’m asking because a battery for another computer of the same model that I ordered from iFixit around the same time last year also recently turned out to be faulty.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Thanks Dan. Just added the CoconutBattery shot.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sadly your battery is bad! The micro-controller within it has failed so the communication to your system is not working as well as the charging of the battery.
Time to replace it! I would contact the seller to see if they offer a warranty. As an example iFixit offers a year.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Try replacing the battery again. If that doesn’t do the trick, that is when you should either replace the logic board or the whole MacBook altogether.
Bewertung 1
1 Kommentar:
Let's first diagnose the issue before we go that far!
von
Antwort hinzufügen
thardee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 36
