@sambodamon
If it is bad enough it can be seen with the naked eye, although a magnifying lamp will make it easier to see.
Even a mobile phone camera may be good enough if the image can be zoomed in.
Here's an image of what moderate to severe water damage can look like.
It doesn't have to be widespread on the board it can be just little pockets of damage here and there even tiny flecks. So carefully and slowly check the whole board especially around the area where you think that the water may have first penetrated
Boards can get dusty over time so don't confuse what may be just dust (which is not good in humid situations) instead of corrosion. Surface dust may come of with a gentle brushing using a soft brush and a vacuum cleaner whereas corrosion won't. It needs to be gently removed with a Q-Tip lightly moistened with isopropyl Alcohol 99%+ (available from electronics parts stores).
It may turn out that there is none to be seen but you did say water damage so it pays to check. Even though there may not be any more problems now it can occur weeks or months later as the corrosion, if not cleaned away, will continue to erode the metal parts of components which are very thin to start with.
Be ESD aware and use a wrist strap connected to an earth point and also disconnect the battery from the systemboard. This will ensure that you can't damage the board electrically when inspecting it, either by accidentally touching it with your fingers - ESD, or using metal tools and accidentally shorting out components.
Golden rule with electronics I was taught more than 50 years ago when working on electronics "Power off first, on last except if needed for testing"
Power off in laptops means disconnecting the battery as there is always power on the motherboard, even when the laptop is off. The power button is not a power isolating button.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von Dan
Hi @sambodamon ,
Has the water damage been taken care of i.e. cleaned away any signs of corrosion etc, you didn't say?
von jayeff
@sambodamon - I see pictures!
It looks like your system needs a good dusting. The fan blades look completely caked! Get a small soft paint brush and a can of Can'ed air. Carefully scrub the logic board and fans to loosen the dust and other debris.
The component you have focused in on it a inductor This will need micro soldering tools & skills as well as getting the needed part.
von Dan
