One red line occurs frequently
A red line flickers on the screen frequently.
But it doesn’t appeare on white background
(Red lines appear over the dark region. but the white lights works properly)
Can someone provide a guide to fix it in HP All-in-one 20-r141in
Ist dies eine gute Frage?
A white screen has all the colors on. A black screen has them all off.
That line segment is not turning off the red and is likely a connector issue, but could be the screen or drive circuitry. None of that is a simple fix.
von bill
@ruggb Any possible guidence if it is a connector issue?
von Vikash
You must open the computer up, find the connectors leading to the monitor and for pin type, disconnect/reconnect them, maybe a few times to clean the contacts. In the case of flex cable connectors, rubbing the contacts on the cable gently with a pencil eraser. There are also connectors behind the monitor which are much more difficult to get to.
The trick for the flex cable connectors is not to break the connector when opening. They are very delicate but they do open easily if you are doing it right. Refer to youtube videos. If cleaning connectors does not solve it, then it is either a deteriorated cable with an open trace or a bad monitor.
von bill
