Zum Hauptinhalt wechseln
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 Fragen Alle anzeigen
Is it possible to fix scratched circuit film?
I was checking my joystick because it drifts a little but when i open the green thing, i just accidentally scratched my circuit film, and the D-pad didn't respond when i connected it to the console.
Is it possible to fix the scratch or buy another one?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@fixie_t you could try a scalpel to carefully scrape the covering of each off the trace then use something like a circuit writer pen to connect thos. By the time you have all those materials the cost is probably higher than replacing it. So check prices and see if you are A. comfortable with doing this and B. which is more economical/available.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I think i can buy new circuit film because it’s cheaper than pen. But thanks for the answer.
von
@fixie_t makes perfect sense. Good luck with your repair.
von
@oldturkey03 i think i bought the wrong circuit film. My scratched film (as you can see on the image) is jdm-50 and the thing i bought was jdm-40(i bought it on amazon and it was just like the same as my scratched one). But i wonder if it still works if i put it on my DS4.
Then when i replaced it with the new one, all buttons actually works except R2 and L2 buttons.
von
It may or it may not. All it takes is one connection changed and it won’t function as you need it. I’d try and get the proper part for it to ensure compatibility
von
Antwort hinzufügen
Takumi Terui wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 20
Insgesamt: 375
