Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
552 Fragen Alle anzeigen
MacBook Pro late 2013 wifi no hardware installed
Hello, I got a late 2013 MacBook pro, A1502 emc2678, that works almost perfect but it says WIFI: no hardware installed. I looked inside and saw that the coax connector was torn off on the airport card so I replaced that but even after replacing the card it stills has that same error. I don’t know if the cables are damaged as well or if the logic board is.
Here is a link to the images of the mac: https://imgur.com/a/fccIbiV
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you post some pics so we can see the damage Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
I do see a bit of tarnish on the contacts that should be cleaned. Find a fresh (still soft) pink pencil eraser. Carefully wipe the contacts in the direction of the pins, then wipe down the surface with a damp lintless cloth with 90% or better isopropyl alcohol (reagent quality) see if they helps. otherwise I think you need a new AirPort board.
I don’t see anything wrong with the cables did the connector pop off? If it did you might have a short or not a good connection.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board and the guide MacBook Pro 13" Retina Display Ende 2013 AirPort Karte austauschen
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board Bild
Produkt
$49.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jake Briggs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 116
