Zum Hauptinhalt wechseln
Das OnePlus 6T ist ein Android Smartphone von OnePlus. Angekündigt wurde es am 29. Oktober 2018 und erschien dann am 6. November 2018.
Which component is responsible for the network connection on the mobil
When I am connected to the Wi-Fi network at home, my OnePlus 6t occasionally disconnects from the Wi-Fi network and the mobile network out of the blue for about 20 seconds and then logs back in automatically. If, on the other hand, I switch off Wi-Fi and connect to the internet via the mobile network, the connection has never been interrupted. I have already reset the phone and during the set-up process the same problem occurred again, so it must be the hardware. My question now is, which component do I need to replace? Where is the antenna for the connection to the WLAN/mobile network, is it a separate circuit board or is it on the motherboard? It would be nice if someone could take care of me, as the problem is really annoying, especially when the connection simply drops out during a phone call. Thank you in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
WiFi signalling is handled by the WiFi/BT IC whereas GSM signalling is handled by a different IC.
Try using the phone as close as possible to the WiFi router (<30cm) and check if the connection remains stable.
If it does it may be a loose WiFi antenna connection.
Here’s the ifixit OnePlus 6T Hauptplatine tauschen guide. It is useful as it shows how to open the phone so that access to the WiFi antennae is possible. Go to Step.11 to view one end of the connection. The other end is under the speaker, unfortunately not shown here
OnePlus 6T Lautsprecher Bild
Anleitung
OnePlus 6T Lautsprecher tauschen
Schwierigkeitsgrad:
Mittel
15 - 20 minutes
OnePlus 6T Hauptplatine Bild
Anleitung
Schwierigkeitsgrad:
Mittel
40 - 45 minutes
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
OnePlus Nutzer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 487
