Zum Hauptinhalt wechseln
A1418 | EMC 2889 | Ende 2015 | 1,6 GHz Dual-Core Intel Core i5 oder 2,8 GHz Quad-Core Intel Core i5. Erscheinungsdatum 13. Oktober 2015.
What do I need to purchase if I want to replace the HDD with an SSD?
Looking to replace the HDD in my iMac with an SSD. I have an SSD on hand but want to know do I need to purchase anything such as a temp sensor? I know older models needed some after market temp sensor otherwise the fan would run at 100% all the time. Is this still the same with this model or am I able to replace it without purchasing a sensor? What else would be recommended to make this process easier? I know I will need the little cutter that ifixit sells and some new adheasive. Any recommendations are also welcome.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Here’s the guide iMac Intel 21.5" EMC 2889 Festplatte austauschen
You don’t need any thermal sensor for your system, But I strongly commend you get the tools and sundry items listed out here iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit And make sure you follow the guide to the letter using the special cutter wheel as many people have damaged their display using the wrong tools.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit. Bild
Produkt
$117.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Dudefoxlive wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 326
