Why are both of my analog sticks clicking after a clean?
After doing a clean on an old ps4 controller and getting rid of the stick drift, once I checked the both analog sticks it all of the sudden makes a very loud clicking (one click) noise and resisting whenever I push. The noise and resistance only happens after moving the stick in the down direction, also when moving counterclockwise at around 180 degrees (search up "360 angle" for reference of the 180 degrees). Also there is a very sleight noise when moving the stick in the every other direction, but there is no resistance.
I tested moving both analog sticks without the green things touching and that does not seem to be the problem. If more info is needed I'll provide what I can.
Ist dies eine gute Frage?
3 Kommentare
When fixing the drift, you only changed the green things that are on two sides of the stick, or did you replace the whole stick?
Can you see anything inside the sticks that looks like they have broken off?
von Erik Eriksson
@eke0909 I haven't changed the green things or replaced anything as of yet. On the outside I'm sure that nothing has broken off, but the inside is something that I'm unable to see.
von 4ThaWin
I had the exact issue clicking feeling and sound literally after trying to clean the sensors on the right stick but i just pushed down the stick and pulled it downward toward the clicking and it stopped
von Blessing Yama
