Zum Hauptinhalt wechseln
1.6 oder 1.8 GHz Dual-Core Prozessor, 2 GB oder 4 GB SDRAM, 64 GB oder 128 GB SSD
Why do some key take long to use. QWERTYUI
On my macbook air. The top keys of letters are really slow to respond. Sometime it takes really long time! All other keys work.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The keyboard response differs depending on what you are using for an app. As an example filling in a form online can be slow as the connection is either not stable or over a slow link. But the keys across the keyboard should respond the same.
Here you are stating a sub set of keys react oddly, I'm suspecting your battery is pressing on the keyboards cable which is interfering with the signal. To prove it you should see a difference between your systems keyboard vs an external keyboard either a Bluetooth or USB connected.
I would install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen so we can see what the batteries state is.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Thank you for the advise. I suspect that the battery is pressing the keyboard cable. I changed the battery and probably in the process I might placed it wrong. I will do the replacement process again.
von
@Ruben Cañas Lindh - Check the keyboard cables connection point on the trackpad MacBook Air (11 Zoll, Mitte 2011) Trackpad austauschen corrosion is also a possibility.
von
Im having trouble puttin the keyboard back on the connection pad. Is there any step-by-step guid to put it pack?
von
@rubl - Post some images of the cable end and the socket so we can see where you are Bilder zu einer vorhandenen Frage hinzufügen
von
Antwort hinzufügen
Ruben Cañas Lindh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 225
